Old 07-04-2010, 02:14 AM   #2
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
There are three bolts at each side of the base of the convertible top frame at the bottom of the B-pillars. To get to those bolts, you first put your top in service position. Look up how to do that in your owners manual if you don't know how.
Loosen (but don't fully remove) those bolts on each side, and then have a friend pull the whole top as far back as possible (towards the back of the car), while you retighten the bolts on each side. That will make the latch clear the windstop.
