Originally Posted by Wret
Can you explain why this is important? Logically, side to side tire differences could cause handling issues, but front and back? If the rears are worn, they're already different than the fronts. What harm is it to put new ones on the back and wait to get full usage from the front before replacing them.
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=31
"How many tires do I need?
Since tires affect the personality and performance of your vehicle, all four tires should be as identical as possible or handling problems may arise. If your tires don't match, it is possible that one end of your vehicle won't respond as quickly or completely as the other, making it more difficult to control.
A PAIR OF TIRES?
If two of your tires have a lot of remaining tread depth, but you need to replace the other two because they were damaged or have worn out, you should replace them with a pair of tires that come as close as possible to matching your existing tires. While identical new tires are desirable, others of the same size and type can also provide good results. Only consider selecting new tires that are from the same tire category as your existing tires. New tires should be installed on the rear axle."
