Old 06-29-2010, 11:27 AM   #2
jhandy
its your ignition switch. cheap audi replacement is advailable. I bet your radio will not turn off either.
does it make the clunk sound when u take the key out?
try this,
with the key in, turn it to the off position and pull quickly, allowing the clunk sound to clunk harder. also some electircal cleaner sprayed into the key hole may clean the contacts.
if that does not work, then just buy a new switch (10$) and install it in 45min-1 hour.
2002 S
jhandy is offline   Reply With Quote
