Originally Posted by Oaktown 986
I have a new serpentine belt I put on (with great difficulty) and mine is making the sound at low speeds and idle. It's like a constant squeaking that I can only hear top-down and at idle... also my temp. light is flashing now but the temp is totally normal even though we're having a heat wave.
Mechanic time?
Squeak- pull your inspection panel behind the seats and see if you can identify the source. Too much tension on the serpentine belt can cause water pump bearing failure over time. If the water pump or any of the idler pulleys turn with resistance, wobble, or noise they should be replaced.
Flashing Temp light- low coolant level or failed radiator fan motor.
