Originally Posted by Topless
I have heard similar squeaks on other Boxsters:
1. Serpentine belt/ worn pulley bearings -no biggie
2. Water pump going south- biggie (possible engine overheat in near future)
3. loose spark plug (more of a chirp I think)- no biggie
4. Worn timing chain tensioner guides - A real serious biggie (motor probably would have grenaded shortly if this was not found and repaired in time)
I recommend you do not ignore this. It may be nothing, it may be everything.
I have a new serpentine belt I put on (with great difficulty) and mine is making the sound at low speeds and idle. It's like a constant squeaking that I can only hear top-down and at idle... also my temp. light is flashing now but the temp is totally normal even though we're having a heat wave.
Mechanic time?
Jonny Wonder
1999 Porsche Boxster 5 Spd
Stock, with GAHH A5 Glass top.
Previous Toys:
2005 RX-8, RIP
1989 GTA, 5 Speed, Procharger Supercharger and 2 Core Intercooler, 1 3/4" headers, 3" Flomaster Exhaust, cat-delete, digital ignition, bigger fuel injectors
