Your toe will be significantly affected by your camber change. In fact, that probably accounted for more handling difference than the camber change.
When I went from the stock to maximum front camber, I ended up with 3/4 inches of toe out!! Makes the car turn in pretty good at autox, but not great for freeway driving or for tire wear.
You will want to get your toe reset ASAP.
Demick
'04 Boxster S
