Old 06-23-2010, 07:05 AM   #1
Cartel
Originally Posted by Gary H
Thank you. They're the Lyras. The lights plug into each other , so there's only one loom to feed into the car: One Switched Pos, One Neg and a tap off your parking light or dipped beam - which dims the lights when either the parking or dipped (depending on what you hook up to) are switched on. They look OEM and are Audi bright!
The splitter was a cheap copy off ebay - although I'm not sure what it's a copy off. Luckily I've got a good body shop, so it did need some fine tuning - glue and screws (bolts actually)
It doesn't affect ground clearance at the front although my only slight criticism is that the sides now sit maybe an inch lower so look a little 'heavy' in my eyes and I've already caught one corner. But apart from that, it's all good.
Many a thanks. My last request are for a few photographs of the vehicle illuminated at night!
2003 Porsche Boxster S 3.2L l AASCO Lightweight Flywheel l FVD Brombacher ECU l FVD Brombacher 100 Cell Sport Catalytics l FVD Brombacher Sport Headers l GiroDisc 340mm FR Rotors l IPD Intake Plenum l Litronics l KW Variant 3 Coilovers l Porsche 997 75mm Throttle Body l Road Sport Supply Underdrive Pulley Kit l Sachs Stage 2 Racing Clutch Kit l TechArt Short Shift Kit l TechArt Power Flow Kit l TechArt Sport Exhaust.
Cartel is offline   Reply With Quote
