Thank you. They're the Lyras. The lights plug into each other , so there's only one loom to feed into the car: One Switched Pos, One Neg and a tap off your parking light or dipped beam - which dims the lights when either the parking or dipped (depending on what you hook up to) are switched on. They look OEM and are Audi bright!
The splitter was a cheap copy off ebay - although I'm not sure what it's a copy off. Luckily I've got a good body shop, so it did need some fine tuning - glue and screws (bolts actually)
It doesn't affect ground clearance at the front although my only slight criticism is that the sides now sit maybe an inch lower so look a little 'heavy' in my eyes and I've already caught one corner. But apart from that, it's all good.
