Old 06-20-2010, 11:01 AM   #13
gwellman
I'm having a coolant problem in my 03S as well. Two weeks ago my low coolant light started blinking and it's been losing coolant pretty consistently ever since (coolant light will go off about 3-4 days after topping off if I don't keep up it with). I tried replacing the cap without success.
Today I finally took off the under panel to get a good look at it. The location of the leak seems clear, although I couldn't get it to leak as much as it has been. Pictures are attached. Thoughts? Does the water pump need to be replaced?
Best,
Greg
gwellman is offline   Reply With Quote
