thanks folks, this sounds like a good direction to go. two questions:
- if i chose to upgrade my droplinks as well, then i would note than the gt3 front sway is only $10 more that an m030 and is lighter; would it make sense to go this direction even though i would be running it at full soft the whole time?
- i've seen some dialogue about the standard vs 'S' versions of m030 suspension. any advice on how this affects swaybar selection and, should i decide to eventually upgrade shocks/springs, if there is any variation here between standard and 'S' versions?
thanks for your advice and patience with my pestering. trk.
