Old 06-20-2010, 07:26 AM   #7
extanker
Originally Posted by crios
I had a similar noice...clunk...cluck....cluck sound, real loud, did not sound good at all. Took it to the dealer, they said the brakes were sticking, cleaned then up, went away for a couple of months, then it came back.
I didn't want to take it back to the dealer, $400 for nothing, so I took it to an Indy should, they opened it up and found the below damaged, which was causing the issues.
If after you jack up the car, the noice goes away, could be this, this is what would happen to me. If could also be the trannmission as well? I'm getting a rebuilt not, broke 2nd gear, and that sounded like a bunch of rock in an tin can...all other gears worked fine.
Before:
After wacking it back to shape:
those darn self-tightening bolts again
extanker is offline   Reply With Quote
