Did you ever get around to measuring the 2003/4 OEM glass window in your soft top? I am curious as well. I would like to get a feel for how much bigger the OEM glass is than GAHH or Robbins. Thanks!
Also, any one have a good source for 2003/4 convertible tops with the 4-bow frame?
					Originally Posted by Boxtaboy
				 I can measure for you next time I go to my garage, but I don't think the main appeal of the 03-04 window is the size of the window.  I think the main appeal is that it doesn't limit engine access, with the larger glass area and OEM fit/look as secondary.  As for whether or not worth doing, I think that's a function of what price you can source it for...if found at similar to price of GAHH or a few hundred higher, I think it's a no brainer.  If much higher, then maybe not.
 Another thing is that it is actually a lot easier to just swap the entire top frame than stripping off your old top from the frame and installing a GAHH over the old frame.  That would usually take at least twice the time to do vs. just swapping out a top frame.  The exception would be if you had a pre-2000 model, in which case you'd also have to modify your top relay/transmission set up.
