Old 06-15-2010, 07:56 AM   #10
Cloudsurfer
Originally Posted by Bud
Thanks for the input, I do have the projector beam on top (for low beam) and the high beam below it. I think it's a bit different then the 986 setup. I imagine the projector makes the beam pattern, not the light source? Anyhoo I'm going to give it a go w/ 6000K bulbs unless some says something will blow up! If anyone has done a 987 just chime in with any advice,
Cheers,
Bud
Since you already have projector lows, you can do an aftermarket kit, but really try to search around and find a high quality kit, vs the $20 special you'll find on eBay.
Either way, they're still not going to match Litronics.
Boxster S
