Sticky ignition cylinder
My ignition cylinder is acting up - key hard to insert, doesn't want to spring back from the Start position, and doesn't re-set itself when I remove the key so the car thinks the key is still in (door chimes). Any suggestions before I head to the dealer and spend a fortune to have it replaced? ('03 Boxster). I've tried spraying some silicone into the cylinder - may have helped a little, but not nearly enough. Thanks.
