Old 06-11-2010, 12:48 PM   #3
Dave928
Location: Seattle - It's not Hell, but you can see it from here!
if the window regulator is starting to bind, the window controller could see that as a pinch condition and reverse the motor.
try this: roll the window up and grab the top of the glass and pull up at the same time. you're lightening the load on the motor. you might have to try a few times with increasing amounts of pulling tension. if it goes all the way up then you know what it is.
probably need a new cable/regulator assy and window guides.
dave
2001 Porsche Boxster S
1988 Porsche 928 S4
Dave928 is offline   Reply With Quote
