Based on what you describe I would say you have the new style transmission. You can pull the drive cable with the square end out of the plastic housing with your fingers with the new style.
Can't do that with the old style as the other end of the drive cable is crimped to the worm gear and we need vise grips or heat to get it out of the worm gear. Or for some reason you cable is not properly secured to the worm gear if you have the old style.
