Old 06-10-2010, 06:44 PM   #1
mafiapete
Hi tonycarreon,
Would you like to try something I'm currently trying out?
With some advice from Maurice, a regular from renntech and I think under a different nick here, I have removed fuse B6.
This disables the convertible top, and so I suspect the entire top relay. Not sure if this will fix your issue, but could be a short cut to prevent the windows from dropping during a rainstorm! Haven't really tested it, but will update you.
When you want to put the top down, simply insert the fuse again. Much easier than taking out the double relay imho...
Cheers!
Peter
mafiapete is offline   Reply With Quote
