Old 06-08-2010, 06:52 PM   #1
mafiapete
Sounds so much like my problem. But mine is more consistent, happens to both windows by the same amount, and only when the top is closed.
I read somewhere that your symptoms could be the microswitch at the door handle that is going wrong / stuck? Think suggestion was to use the key on the door, turning to lock and hold for a few seconds, then turning to unlock and hold for a few seconds, and do this a few times.
I'm starting to hate relays, so you might want to try pushing all the relays under the right side footwell to make sure they sit in tight.
mafiapete is offline   Reply With Quote
