Old 07-02-2005, 08:03 PM   #18
bigislandboxster
One more thing Randall!
On the lower plug on the Becker, you'll see a connection for the power antenna.....I believe its in spot # 5.......Your wiring harness with the Alpine should probably have a connection for the antenna as well, so cut that wire on the Becker and connect to the antenna wire on your Becker.
The switched power terminal, spot#6 on the yellow upper Becker plug, needs to be connected to your power amp wire on your wiring harness as well.....This will switch the power on to your amp when you turn on your head unit....
I think thats it!
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
