Old 06-06-2010, 07:31 AM   #1
jhandy
Thats the RMS and cam cover leak. very common. the RMS should be fixed, and do the clutch and IMS upgrade from LN Engineering at the same time.
About 2000$ for all of this. If you dont do it all, you will be very sorry, as the labor is the majority of the expense and you will want / need to do it anyway in the future.
the creaking suspension is also common. If you are not a DIY person, then you can let the creaking go for now. If you want to fix it yourself, then try vertex auto for OE arms at a huge cost savings.
search for the following and read as much as you can.
IMS, RMS, http://flat6innovations.com/.
2002 S
jhandy is offline   Reply With Quote
