The fact of the matter is, most, if not all, of the "high end" wheel companies (particularly, the ones that you mentioned) begin their line up of wheels starting with size 19. Therefore, for those of us who embrace the concept of less weight/rotational mass, there are few choices but to move up to said size and spend the money. Otherwise, unless one is looking to simply change the appearance of their vehicle, they are better off leaving the oem wheels in place.
Again, your original post implied that the objective for everyone should be to embrace the concept of less weight/rotational mass, but my point was that not everyone necessarily has that objective when sizing up. Some just want to size up for looks, or just want cheap larger looking wheels for asthetic reasons, which is why you see so many replica wheels out there. These type of consumers don't care if they lose a little performance by sizing up with heavier/larger wheels.
In addition, there are wheel companies like OZ and others that offer 18" lightweight wheels too. Just because you buy a larger lightweight wheel, you still have to pair it with the larger rubber, which also is heavier than the smaller sized tire, so you don't always end up on the better end with a larger set up, performance-wise. How many people do you see track their cars with 19" tires/wheels? In many cases, a smaller tire/wheel set up will yield faster track times vs. A large 19" set up. I also distinctly remember an article in Excellence on a Manthey Racing (sp?), prepped 996 with upgraded engine and suspension, and they specifically put 18" wheels/tires on the car because they said that the car performed optimally on 18s.
