Old 06-03-2010, 08:27 AM   #2
tonycarreon
tonycarreon's Avatar
check pedro's garage http://www.pedrosgarage.com/Site_3/Clean_the_Throttle_Body.html
Originally Posted by Pedro's Garage
Now you can start to remove the throttle body which is secured by 4 bolts on it's base and 2 hose clamps. The two uppermost bolts are easy to access.
The bottom ones require a little patience especially the one on the right side which is not visible unless you use a mirror. A short extension on a ratchet is handy.
Once it's out, make sure you clean all the passage tubes. You can use alcohol or electric parts cleaner. Some people use carb cleaner, but I personally think it's too harsh.
