Originally Posted by jmcl
P1319
Factory Fault Code 62 - Misfire, emission related
P1314
Factory Fault Code 51 - Misfire, cylinder 2, emission related
P0300
Factory Fault Code 75 - Misfire damaging to catalytic converter
P0302
Factory Fault Code 64 - Misfire, cylinder 2, damaging to catalytic converter
Found this post
http://www.boxsterforum.com/forums/showthread.php?t=24701
Sounds similar.
Should i change the ignition coils?
Maybe swapping the ignition coil on cylinder with other cylinder?
Any suggestion?
Txs.
John
