Old 06-01-2010, 05:08 PM   #14
Lobo1186
well unfortunately to get them out you need to remove the bumper honestly it doesnt take long at all. with the correct drivers maybe 5-6mins (maybe more the first time since you are trying to find all the screw points) after that they pop right out.
using a paint scraper or razor blade you need to scrape off the gray faded plastic. takes a little while but the preparation is key seeing as painting plastic is tricky. I used whatever satin black paint I had lieing around I think it was rotor paint LOL but I know bondo makes a satin black plastic paint. after that spray paint away let dry and put it and viola 100 times better looking.
the plus side is if you do need ur car daily and you want some extra time to prep you can just put the bumper on with the grills while you prep and paint also great benefit you can clean your radiators!
