you can try taking a jumper wire and go to a KNOWN GOOD GROUND and then to the motor...if no joy try jumping 12 volt to switch....use care on jumping...some p/w use DPDT switchs...they reverse the pos/neg...other words ..one switch position a wire could be a ground another position the wire could have voltage
Reason: more info [warning]
