Yes...the window motor itself was buzzing...but it does nothing else. I thought it may be siezed up, but I hooked up a direct power source to the motor after I took it out of the car and off the regulator and the window motor worked perfectly. I reattached it to the wiring harness without putting it back on the regulator...andwhen I hit the power switch, the motor just buzzed again. I think I am getting a low voltage current to the window motor which is causing the the motor to buzz (isn't getting enough juice to power the motor...so it buzzes)...but....where is the current getting hung up...
