Old 06-01-2010, 10:02 AM   #10
Cloudsurfer
Sorry, but I just can't endorse using plumbing materials from Home Depot on an automotive application.
Want to do this the right way? Get the appropriate sized silicone elbows, aluminum hard pipe, and silicone joiners.
Aside from that, on a stock motor, what is supposed to be the gain here? It's been proven that the factory airbox and filter flow plenty enough air for the motor, and inserting thick wall PVC pipe (which probably has a smaller inside diameter than the factory thin wall plastic) and Fernco elbows (the black rubber things) between the air box and throttle body is not going to get you any increase in air volume sucked through the throttle body.
Boxster S
