Here are your options to go more than 1 degree negative camber:
a) camber plates
b) GT3 control arms
c) lower the car with (stiffer) lowering springs, this changes the whole geometry of the front (and rear) axle so that you can get more negative camber. I did this and got -1.75 degree
d) you can also go balls out and install adjustable front and rear sway bars and now can dial in any kind of over and understeer
but wait, there's also e): go wider on the front tires (example from 205 to 225), this increases the patch area in the front and dials out some of the understeer
