I ended up hooking the system up but I'm having a problem. I keep hearing a faint whining sound. As if it's feeback or something. It's more easily noticeable when the volume is the same but a part on the song goes down. The intensity is directly proportional to how fast I am traveling. This is probably why I didn't notice it when I had everything setup initially from a standstill.
It only occurs on my AUX output and not any others. What I've done is basically separated the RCA's from the CD changer using a splitter so that one output is the cd changer and the other is a 3.5mm. I installed a switch using regular thermostat wire to allow me to cut off power to the cd changer and allow me to use the aux input. Any ideas as to why I'm hearing that feedback type noise?
