I purchased a obd2 reader today and only read two codes.
1.)p1133= oxygen sensor, adaptation, lower load bank two above limit.
2.)p1126=o2 sensng range 1 cyl 4-6
Neither pertained to the transmission. I knew it was getting to be time to change out my 02 sensors so no suprise there.
I think I am first going to change my tranny fluid, yes I did read up on it and know it isn't the easiest one to do. I have done my: oil, plugs, fuel and air filter. I also changed my alternator this year. I have some mechanical skills, albeit limited.
1.) Where do you all suggest to get the parts? Automatic transmission filter & gasket kit and fluid(might as well get some 02 sensors also).
2.)How much fluid is generally needed.
3.)Anybody have a site they love for the DIYer for this project? I usually use Pedro's garage.
Worst case scenerio is I will have to flat bed it to the nearest P-mechanic or worst of the worst case scenerios take it to the stealership
