Old 07-01-2005, 12:50 PM   #2
Pablito
Thru the wheel well you need to remove the fender liner and the fan shroud...you can actually see them if you raise the car enough and look thru the opening under the headlights assembly...for a better access you can also remove the front bumper cover and you will be able to see the entire mechanism...
Pablito is offline   Reply With Quote
