Old 05-26-2010, 02:33 PM   #2
Aron in Toronto
If you haven’t already looked into the headlight light switch, you may want to look there it is known to wear out.
I would also recommend doing a search for faulty ignition switch problems as they are also known to go bad and when they do they will produce strange electrical gremlins.
I haven’t heard of any faulty current distributors on the forums other than one & it seems that was possibly a result of reversed polarity of the battery.
You should also be aware that there is only one rear fog light.
Headlight switch DIY
http://www.renntech.org/forums/index.php?/topic/3131-ac-side-air-vent-removal/page__p__14785&#entry14785
Ignition switch DIY
http://www.pedrosgarage.com/Site_3/Replace_Ignition_Switch.html
If you’ve already looked into these then hopefully someone else will be able to steer you in right direction.
1997 Boxster
http://i40.tinypic.com/ax1qhz.jpg
Aron in Toronto is offline   Reply With Quote
