Old 05-22-2010, 04:00 PM   #1
mojosung
Help please! How to remove the current distributor from car - fusible links
Hello,
I have problems with the fog light on my 2001 2.7 Boxster 986, no power to the relay. Also the low beam not working, dont know why yet.. so I now traced the curcuit to the current distributor and wanted to check all the fuses there. I loosen up the nuts that holds the current distributor from the battery side, then tried to move the distributor off in the passenger footwell.
But then I found the clearence between the current distributor and an air box too small? Can someone had taken the current distributor off please help me and tell me how you took it off? Thanks. Help please!!
mojosung is offline   Reply With Quote
