I added the UV dye and ran the car for a while. I pulled off the under-panels and looked at the water pump area, radiators, and the coolant fittings. Still no luck on finding where the coolant is going. The oil doesn't appear to be glowing. But I'm not sure if there was coolant in it, it would be enough to show up.
I'm still noticing the sweet smell when I start the car hot. So it's going in to the mechanic on Tuesday.
