				Bad bearing.
			I had the drivers rear go bad.  It squealed rather loudly but was most noticeable at about the 20 to 40 MPH range when driving window down with a wall along side the car (on a bridge, in a city, etc.)  At highway speeds road noise was too loud to hear the squeal.I verified it was bad by:
 1.  Washing the car and pressure washing the wheel area.  Small pebbles in the brakes/shrouds can cause a similar problem.
 2.  Drive at a speed where you hear the squeal.  Change lanes back and forth (or turn) without changing speed it will momentarily get louder or go away (If you can drive by a friend at speed he will hear it when you do not.  The squeal is very audible outside the car not in it without a reflective surface alongside the car.)
 3.  Jack up the rear of the car (both sides) and put on jack stands.  Remove the wheels and verify the brakes and e brakes are retracting.
 4.  Check for rubbing of the medal shroud around the disk. On two occasions I have fixed a squeal after a state inspection of the brakes (they replaced the wheel without using the alignment pin -- a difficult task if you are not talented/careful)
 5.  Spin the hub. I could feel it dragging in comparison to the other hub.  As I increased speed the bad side made a rubbing sound the other did not.
 6.  The on road tests may indicate a problem due to wheel alignment, tire wear, or balance issues.  So if you hear a noise on the road do both the garage tests.
 If you are hearing a whoomp, whoomp, whoomp vice a squeal the bearing is about to fail which can double or triple your repair cost.  So get it fixed now!!
 I have done bearings on about 30 cars.  Modern American, Old British, Japanese, I would not hesitate to do most repairs but this is a bit more difficult and requires tools you probably do not have access to.  It cost north of $600 at a dealer for the repair (obviously depends on the area/dealer.)  A decent local shop can do the job and usually asks about $300. If they hesitate or admit they have not done this repair before -- I would go else where.
 Hope this helps.
 ATB,
 tom
