Originally Posted by sasha055
I inspected CV boots axle and tire wiggling all apeear to be good..
I noticed a small drip of liquid near passenger side rear tire.
It comes from something that looks like a cut rubber hose about 5cm to the center and front from CV boot. I couldn't really tell what the liquid was.. it was yellowish without smell.
Can anyone please tell me wht that "cut rubber hose" is for? and what kind of liquid could be coming from there?
Sasha
Sounds like one of the body drains. Did you have this noise before you replaced the tires. What kind of tires did you put on the Box. Did a Porsche shop or Indy do the alignment. The cambor and toe need to be set to Porsche specs, but, if your Box has hit something from the previous owner, then those specs may cause the tire to whine. They need to measure it to make sure it is true.
