Old 05-16-2010, 07:59 PM   #6
brett914
pump replacement
I just completed a pump replacement on my 02 Boxster S. It had to be about the easiest water pump replacement I've ever done (so far). The wierd thing is the car still overheats event though the reservior appears full. (I will take the bleeding suggestion above)
On a related note, the plastic impeller on the old pump had all its fins chewed off (new one is metal)....are those little pieces of plastic in the system causing issues?
brett914 is offline   Reply With Quote
