Old 05-13-2010, 05:53 AM   #3
smeech
Brilliant. Thanks a lot. One further point - i'm not sure if my ignition switch is busted as it is difficult to get it to "0". If I plug the battery in and the ignition is trying to get to "1" but i've taken the key out so it is stuck at "0" do you think this is more likely to bust it and therefore I should insert the key to position one to be on the safe side? Ie will it cause any problems if I do put it to position one when inserting the new battery?
smeech is offline   Reply With Quote
