Originally Posted by Cloudsurfer
You absolutely do not want to run a non-sprung clutch on a single mass flywheel. There is a Sachs sprung clutch disc, which if you're on a stock motor, is what I'd do and save the money.
that's what i thought. what you think about this:
this was the only thing I could find.
http://www.vividracing.com/catalog/sachs-high-power-clutch-disc-porsche-boxster-cayman-04-p-53196.html
I am going to also use a harmonic dampner on the front crank pulley also. hopefully that will be enough to keep the engine in one piece.
