Old 05-12-2010, 10:13 AM   #7
2K3_Boxster_S
Originally Posted by Cloudsurfer
All of SPEC's clutches up through Stage 4 are sprung centered. They are different clutches depending upon if you are using a 5 or 6 speed gearbox. You select the clutch based on the gearbox, not the engine. The amount of torque that the motor makes determines which stage you need.
did you check out this link??
it's basically saying that all Spec Clutch kits for my car will come with an unsprung disk.
http://www.horsepowerfreaks.com/performanceparts/Porsche/Boxster/Clutch/Clutch_Kits
I was wondering how people were using a Sachs clutch with the LWF setup. I finally found a site where they sell a Sachs sprung clutch disk. guess they are using this disk. I can't see using an un-sprung disk (which comes in there standard performance clutch kit) on a Single mass. or I could be wrong. everything I have read suggest using an unsprung disk on LWF is a bad idea.
Thanks for the Info on the SPEC. i will check it out.
2003 Boxster S
2K3_Boxster_S is offline   Reply With Quote
