Old 05-11-2010, 07:59 PM   #6
Cloudsurfer
Originally Posted by 2K3_Boxster_S
Thanks for the help.
Now I am looking at SPEC clutches and it looks like they are going to send me a Un-Sprung Clutch disk if I order one for a 3.2.
Am I suppose to order a clutch kit for a 97-99 boxster???? are they compatible with the 3.2??
http://www.horsepowerfreaks.com/performanceparts/Porsche/Boxster/Clutch/Clutch_Kits
All of SPEC's clutches up through Stage 4 are sprung centered. They are different clutches depending upon if you are using a 5 or 6 speed gearbox. You select the clutch based on the gearbox, not the engine. The amount of torque that the motor makes determines which stage you need.
Boxster S
