Old 05-10-2010, 06:00 AM   #2
amondc
From what you are describing it sounds like you are fine with the jack. You can pull the motor and trans as on and split when its on the ground to make it a little easier. If you are going to pull the trans first then you need to support the engine either from the top or the bottom.
amondc is offline   Reply With Quote
