water found
At first I did not see anything leaking in what I thought to be the problem area, under the motor and filler tank. Well I went to the front to listen to hear if the fans were running, as I looked down and low and behold there is water. I found a large puddle on the ground right under were I would be sitting my arse in the drivers seat. I moved the car again by hand to see if it would continue and it did. So at least I know about where it is coming from. Now I will just wait out the 103 degree temp that is being shown in the garage.
