You shouldn't have any idle or running problems with a LWF on one of these cars, however, I would strongly advise adding the harmonic damper to the front pulley (you keep your pulley, the damper goes in front of it and you need a longer bolt).
A sprung centered clutch disc is a MUST. I'd go with a SPEC clutch.
Boxster S
