Thanks for the suggestion Burg. Yes, you are right about remembering the balance setting for the different sources. Unfortunately, the volume is still low on the right channel compared to the left when the balance is set to center in any of the sources.
I took a quick look at the amp in the trunk and am still trying to figure out how to even take it out without removing some trim pieces inside the trunk to get at one of the screws that hold the bracket (the right one).
Ron
