Old 05-02-2010, 11:03 AM   #2
Lucky
Bradster,
There are several fans, some of which can run at multiple speeds.
One fan you should hear from time to time is the engine bay cooling fan -- it is behind the right side air "scoop". It isn't very noisy, but it does (and should) start to run on warm days when sitting at a light for more than a few minutes.
The front fans that pull air through the radiators rarely run unless the car is stationary for several minutes. However, when you have AC turned on, one of the front fans will run constantly to keep air moving over the condenser coil -- you'll also notice your temp gauge will move down a bit. Oddly enough, your car will run slightly cooler if you turn the AC on.
As far as is the "0" in 180 too hot? Not really. Most of us see our gauges go that high on warm days. Some believe the Boxster (and most modern Porsche motors) run too warm in their quest to reduce emissions. Some replace the thermostats with lower temp versions (ones that open up at a lower temp). After owning an air-cooled 911 for many years, my opinion is that Boxsters do not run too warm... if they did, they would be spewing coolant in the trunk all the time.
-- John
'00 Boxster S
'86 911 Carrera Coupe (Sold)
Lucky is offline   Reply With Quote
