Old 04-30-2010, 04:49 PM   #3
Viper5
Thank you for your input. I have changed tranny oil with redline about 10k ago. It doesn't "pop out" once it's in the gear, however it is sometimes (around 40% of time) grinds as I'm trying to put it in gear. Only happens on 2nd gear. I can feel the vibrations (grinding feeling) through the shifter. When it grinds, I have to put clutch back in, put shifter back in neutral, give a little gas, and release clutch until it works. I don't think it's ever taken more than 3 times to do that before it works. Normally once does the trick but it is rather annoying.
I know from at least 60k there was a mount replaced since I bought it from a guy who had it replaced and didn't own it until 60k. Right now there is 110k.
I thought even if the synchro was bad, it wouldn't grind the whole time in gear (only when trying to engage the gear which is what I'm experiencing). According to your diagnosis, since it is only grinding while trying to change into 2nd it would be the linkage. Do I understand you correctly? And why do you say mount is bad for sure?
Viper5 is offline   Reply With Quote
