Old 04-30-2010, 03:36 PM   #2
jhandy
just because it is an emergency, you can get a wire, strip both ends, and connect the two wires, this will bypass the switch, the light should turn on, top up. replace switch when you have it.
if you force the top manually, you need to undo the motor, or you could damage it.
2002 S
jhandy is offline   Reply With Quote
