Originally Posted by extanker
the brake line maybe held on by a 'banjo bolt' it can have 2 crush washers that are supposed to be used once. they can be leaking or the bolt can be loose. the line where it swagged can be old and leaking. i dont know what year it appeared in but does this car have "hill assist" ? on the dragging brakes : fix leak first then jack up each wheel ...apply brake then release...look /feel for one wheel dragging...if so maybe stuck caliper/stuck pad/ crushed [inside] brake hose...if all 4 wheels drag...back track system.....if just fronts drag...back track..if just rears
it's def. one wheel dragging (front passenger) and it's a 99, no options. I think the seal from the line to the caliper is bad.... any thoughts?
Jonny Wonder
1999 Porsche Boxster 5 Spd
Stock, with GAHH A5 Glass top.
Previous Toys:
2005 RX-8, RIP
1989 GTA, 5 Speed, Procharger Supercharger and 2 Core Intercooler, 1 3/4" headers, 3" Flomaster Exhaust, cat-delete, digital ignition, bigger fuel injectors
