the brake line maybe held on by a 'banjo bolt' it can have 2 crush washers that are supposed to be used once. they can be leaking or the bolt can be loose. the line where it swagged can be old and leaking. i dont know what year it appeared in but does this car have "hill assist" ? on the dragging brakes : fix leak first then jack up each wheel ...apply brake then release...look /feel for one wheel dragging...if so maybe stuck caliper/stuck pad/ crushed [inside] brake hose...if all 4 wheels drag...back track system.....if just fronts drag...back track..if just rears
